Viewing 15 posts - 31 through 45 (of 209 total)
  • June 25, 2025 at 8:35 am #1796
    I am pretty sure that xampp is case sensitive. This means that EmptyWorld.vrml and emptyworld.vrml are two different file names for xampp. Make sure, your spelling matches the folder name/file name exactly.
    June 23, 2025 at 11:45 am #1791
    thank you for putting me on CC
    June 23, 2025 at 8:27 am #1789
    All questions regarding the XR4ED shop must be directed to Neofitos. I have no idea why your product isn’t showing up, to be honest.
    June 23, 2025 at 8:25 am #1788
    June 23, 2025 at 8:24 am #1787
    Actually no. And there is no defined screen space since the Portal Hopper can run on a standalone headset which has no screen. So, the PH actually always has a screenspace version and a headset version for all UI interaction. The World Builder does not support that, at least not currently.
    June 18, 2025 at 2:24 pm #1782
    I have one idea looking over your node code. You do a distance check and, once the player is close enough, you call Change Location. But because of the way it is set up, the Change Location node is called 60 times per second (the frame rate which also triggers the Update Node).
    Why not try this first, instead of a distance check, just place a trigger box around the object and respond to trigger enter. This would run a signal only once when you get close enough.
    You could also play “Harry Potter” and create a Portal Object which transports you to a new location when touched. You can use either a trigger zone or respond to a grab signal to achieve this effect. Just say’in… 😉
    June 18, 2025 at 2:13 pm #1781
    I pushed this issue to a colleague of mine who is our expert for runtime scripting. He’s already on it. I am also working to improve our WebRequest Node to be more flexible. Maybe this will also help.
    June 18, 2025 at 2:06 pm #1780
    That surprises me because Neofitos just increased to max upload size to 256MB… please don’t expect this to work.
    June 18, 2025 at 2:04 pm #1779
    Yes, I think so. I just finished upgrading the WebRequest Node to make it more flexible. But maybe we should discuss this in a little more detail at the end of next Wednesday’s meeting. Our next Update is also delayed due to holidays season and another long weekend.
    June 18, 2025 at 1:59 pm #1778
    Thank you! Noted.
    June 18, 2025 at 12:58 pm #1774
    There is no way to integrate APK files into the shop, sorry.  But you could develop your app for PC just as well. In that case you have two options how to proceed.
    a) create a standalone app which is launched from the hopper but does not run in the hopper. To do this, you need a vrml file which defines a DOWNLOAD_AND_RUN protocol and you need to create a single executable installer which can install your app and register it in the registry.
    b) create a scene asset bundle (Unity only) and one or more DLLs which contain your scripts. This can run inside the Hopper. To do this, you need a vrml file which defines a PORTAL_HOPPER_PROTOCOL protocol and must create the scene asset bundle(s) from your app. You’ll also need to get the Designer and Developer toolkits for the Hopper, at least to gracefully exit your game, but you’ll also find other useful scripts in these toolkits (very beta version). Let me know by email if you want to go this way so I can provide the three corresponding packages to you as zip files.
    If you must publish an APK, you have to do it outside of the XR4ED environment through one of the registered VR publishers. For versions a and b, you upload the vrml file to the shop but place your asset bundle or installer on your own server/domain.
    June 17, 2025 at 2:36 pm #1764
    I tested your link (http://gis-perslab.topo.auth.gr/sure-vft/2.vrml) in a test project of mine using the Change Location node and I get the correct world. No missing walls.
    vfragk
    June 17, 2025 at 2:25 pm #1763
    To me it looks like you may have reached the upload size limit. Currently I don’t know the exact lmit, but you may want to ask Neofitos about it. You are not the only one to reach this size limit and I hope we can sort this out soon.
    June 17, 2025 at 8:15 am #1746
    We’ve heard about some projects running into issues with the server due to their size. Although “internal server error” does not sound like a size issue, I’d still like to know how large your project is. Can you check for me? Locate your project folder. Inside, there should be a folder called “Test” which contains the files to be uploaded to the shop. How large is the largest file in that folder?
    June 16, 2025 at 12:23 pm #1744
    I’m on it 🙂
