Viewing 8 posts - 196 through 203 (of 203 total)
  • January 2, 2025 at 2:06 pm #517
    Great comment! Thank you for improving the knowledge base here in the forum. 🙂
    January 2, 2025 at 2:03 pm #516
    Did you install the hopper as well? If you install the portal hopper after the world builder, the WB may not find the hopper automatically and you need to enter the path to the hopper manually. Standard install path is “C:\Program Files (x86)\Nuro\Portal Hopper\Portal Hopper.exe”. You can change that under Settings/Tools/Hopper Path.
    December 12, 2024 at 10:30 am #480
    We definitely want to dynamically add code to the project. This code will be compiled just-in-time on the Hopper side, so it is compatible to the target system. However, the mechanism is not yet ready to be used. In the first quarter of the next year we hope to make this feature available.
    December 12, 2024 at 10:27 am #478
    • This reply was modified 10 months, 3 weeks ago by robert.malzan.
    December 12, 2024 at 10:16 am #477
    I am currently working on a manual entry in the “How To” section to describe what you are looking for. In Short, you create a signal for the button. To trigger something, you connect something to that trigger.
    For on/off behavior of a button (toggle switch), you need to drag the button signal into the Logic Editor and use its flow output and value to implement that. I’ll let you know when I’m finished with my “How To Build a Light Switch with an Interactive Button” tutorial.
    December 11, 2024 at 3:54 pm #463
    Please see the documentation here: https://www.portalsunited.com/docs/task-node-and-complete-task-node/
    December 11, 2024 at 2:56 pm #459
    Currently not. If I understand you correctly, you would like to have an audio recorder which can stream the audio input to a speech-to-text AI which then passes this on to a LLM AI which can answer (as text or again as audio). Correct?
    On our ToDo-List there is actually a similar setup planned for controlling the World Builder (Assistant) and, when done, we could open this feature to you in the form of a node or nodes in the Logic Editor.
    Sometime early next year, we are also planning to finalize the dynamic scripting feature where you can add your own scripts and/or Nodes to the World Builder. This would enable to program a Node which does exactly what you want to do.
    December 11, 2024 at 2:46 pm #457
    Currently, we launch an update every month, or better put, we launch an update when we feel we have something you guys could really use or even need which might be even more often than one a month.
