Issue With Back and Forth Location Change
- This topic has 3 replies, 2 voices, and was last updated 4 months ago by .
Welcome to Portals United! / Forums / Troubleshooting / Issue With Back and Forth Location Change
I have crated a project with two Locations and in each location
1. Have used a simple cube for floor
2. Have added a button to jump into other location
3. created the signal of the button
4. in logic editor i have used button, if and chnage location node
5. Button is click if its true chnage location triggers
6. Change location, external location is used and the link to my vrml file that is put on local server is given
7. For Main location link to location 2 is given and for location 2 link to main locations vrml is given
I started the main location vrml file and clicked the button it jumped to location2 and same way in location2 clicked the button and I came back to main location.
When coming back to same location the floor disappeared and if i go again to location2 the floor is also gone from there.
Simply the changing of location works once going back and again going to second location foor just disappears.
And for the location change if we change the location and go back to the location is there any way we return to same point in first location from where we left to second?
If Possible Please guide how can I achieve that.
Unfortunately there currently is no way to place the user in a specific spot. The starting point is determined solely by the Start Avatar.
