Hand Tracking
- This topic has 1 reply, 2 voices, and was last updated 6 months, 3 weeks ago by .
Welcome to Portals United! / Forums / Troubleshooting / Hand Tracking
We are trying to create some interactions like a button or a switch in the world builder, we want to move with the Hand tracking, the node accessing the hand tracking is Hand? Also, there are no physics integrated in the platform?
Yes, the “Hand” node gives you the hand position and direction. What Physics are you missing? You can assign gravity to an object if that’s what you are asking. The assign gravity, select the object in the Location Manager and select an object type of “grabbable object”. Then you get more options so you can select physics and gravity for the object. Physics means it can collide with other objects and gravity will let the object drop when it is not resting on a surface and not in your hand (grabbed).
