Avatar change size
- This topic has 4 replies, 3 voices, and was last updated 4 months, 2 weeks ago by .
Welcome to Portals United! / Forums / Troubleshooting / Avatar change size
Thanks for sharing this issue. We will look into that.
Are you using any logics in the logic editor, which includes for example, a Rig node?
Can you reproduce this behavior in an (almost) empty project?
Hi Jason,
After removing some of the assets, the problem disappeared, and then it happened again. It looks to me that the problem started again after I uploaded a video. By looking better, it looks like the avatar starts to fly. I cannot reproduce it because it is random, but I got it several times. It looks like it is triggered by some assets, but I do not get what they have in common.
When you say “appears to fly”, could the avatar be falling? This would be caused if the floor has holes in it. If that’s not the case, probably you should send me the project and I’ll check it out. I believe you already have my email address.
