User position tracking in multiple locations
Welcome to Portals United! / Forums / Troubleshooting / User position tracking in multiple locations
- This topic has 8 replies, 2 voices, and was last updated 4 months, 1 week ago by
AnonymousNovember 5, 2025 at 4:33 am #1955
Hello Robert
I have two locations in first location i created a button using that user can go into the other location, on that button click I got the position of the user and stored it into the system parameter. and on start node i created the location so that it can take that stored values and move the user to position where it left while leaving.
to do so i created a kind of flag that tells me if teh user is coming back from the seond location then that moving should perform on start node automatically. But it is not wokring
Instead if i am giving another button for moving then when user comes back from second location and clicks that button it is moved to the position where it left but not automatically.
November 14, 2025 at 7:39 pm #1958I found a solution to your problem. However, I also discovered that setting the last location to the rig doesn’t set the correct values. It sets the camera values instead of the Player values. I am currently creating a new (last?) version of the Portal Hopper which I will upload over the weekend. You will received an updated project file from me on Monday with an explanation on what to look out for when handling player positioning and reading the rig values.
November 18, 2025 at 11:10 am #1967I already sent an email and uploaded a fresh Hopper version before you wrote this message. Did you receive it?
AnonymousNovember 26, 2025 at 10:38 am #1987Hello Robert i found that email and the updated version that was working thank you for that but i found another issue.
That is i have a video that i am importing in assets and in logic editor on start node i am starting skybox as Mono 360 and attach the video i imported it was working but in the same project i create another locations and same logic the video does not play i have tried this in two projects default location works good with video but the new created one does not.
November 26, 2025 at 1:22 pm #1993Please try the following just to help me locate the error. Start the Hopper going directly to the other location first. Does it work then?
Please also send me the links to each of your locations, so I can do some testing of my own.
AnonymousNovember 27, 2025 at 11:06 am #1994Its not working this way as well
i can send you my project by email
AnonymousNovember 27, 2025 at 11:10 am #1995Nothing seems to work in second location on button click i just tried to set text on text object and opened project directly in second locations it is not working still.
December 2, 2025 at 8:11 pm #1999I found the issue. When renaming locations, not all files are renamed properly. I can show you how to fix that manually. Let’s meet on our usual Wednesday meeting.
