Some shortcut are not working
- This topic has 1 reply, 2 voices, and was last updated 1 year, 2 months ago by .
Welcome to Portals United! / Forums / Troubleshooting / Some shortcut are not working
Hello,
I’ve noticed an issue with the undo functionality in the view, not working as expected. When I move an object and press Ctrl+Z to undo, the object does not revert to its previous position as expected. I suspect other keyboard shortcuts may also not be functioning properly also like ctrl+c and ctrl+v.
Steps to reproduce:
Select an object in the view
Move the object to a new position
Press Ctrl+Z
Expected: Object returns to original position
Actual: No change occurs
Has anyone else experienced this issue? Any suggestions would be appreciated.
Best regards
Yes, thank you. Undo is a known issue. However Copy and Paste should work just fine except in the Logic Editor which will be fixed in the next update. Undo will take longer.
