Possibility to replace object with GLB
- This topic has 1 reply, 2 voices, and was last updated 11 months ago by .
Welcome to Portals United! / Forums / Requests & Feedback / Possibility to replace object with GLB
Hello ! I’m currently working on the WB and I’m using the replacement of 3D models a lot when create a new version of my 3D objects. This feature is very useful and works well with FBX. But unfortunately I can’t replace my 3D models with GLB.
Do you think you can add this option to the feature ?
Internally all non-glb models are converted into glb models. If you replace a glb with another glb, the functionality should be the same.
I’m not sure I understood you correctly. Maybe you could describe your workflow and what you’d like to happen.
