Issue With Back and forth change of location
- This topic has 3 replies, 2 voices, and was last updated 7 months ago by .
Welcome to Portals United! / Forums / Troubleshooting / Issue With Back and forth change of location
I have crated a project with two Locations and in each location
1. Have used a simple cube for floor
2. Have added a button to jump into other location
3. created the signal of the button
4. in logic editor i have used button, if and change location node
5. Button is click if its true change location triggers
6. Change location, external location is used and the link to my vrml file that is put on local server is given
7. For Main location link to location 2 is given and for location 2 link to main locations vrml is given
I started the main location vrml file and clicked the button it jumped to location2 and same way in location2 clicked the button and I came back to main location.
When coming back to same location the floor disappeared and if i go again to location2 the floor is also gone from there.
Simply the changing of location works once going back and again going to second location foor just disappears.
Please send me or post here your link to one of the 2 vrml files, so I can have a look what’s going wrong.
I just tested our new multi-location-test feature and it appears to work fine. In the new system, you should reference the locations by their internal location name (dropdown list) and not as a fixed server reference (link with “http:” in it). The hopper will automatically adjust the reference to link to the correct address.
So, please await the new release and see how it goes.
